I couldn't resist quickly hooking up a pattern generator. Had to turn the gain way down, as its signal is strong.
![]() The screen geometry isn't too bad. Not sure what's going on with that warp on the far right edge. This set has almost no horizontal adjusters, so I may just live with it. In addition to vertical height and linearity, it has an adjuster (R5) called vertical bias. Anyone know its purpose? I don't see any mention in the manual, and I don't recall anything like that in old tube TVs. Incidentally, I was wrong about it being impossible to access the boards while powered up. The alignment instructions in Sams say that you can pull either the rear or center board, unscrew its socket(s), slide the socket(s) out through the mounting hole(s), and then plug the board back in. Presumably there is enough cable slack on the sockets to enable this. I may try it tomorrow, just to see if it works. For the record, the manual also gives a procedure for setting the horizontal frequency, first adjusting the stabilizer slug B1 and then the horizontal frequency control as I was doing in the first photo. Amazing what you can learn when you slow down long enough to read the manual. (When I was a technical writer, we had an acronym RTFM, which I won't decode here.) Possibly, I could have tried this in the first place and avoided replacing so many parts, but that wouldn't have been half as much fun ![]() Phil Nelson |
