Didn't get far today, but I found that installing a 1-mfd cap for C34 didn't magically cure everything.
Say that one of those AFC diodes (X28, X29) is bad -- what type would I order to replace it? The parts list only gives a Sony part number (1T261), which didn't turn up anything in a quick search. These diodes are teeny-weeny, not the type of thing I have in the parts drawers.
I'm starting to suspect there's more going on than simply being off frequency. Watching it for a longer time today, the vertical isn't as stable as I thought, suggesting maybe a problem in the sync section or something else that affects both vertical & horizontal sweep.
Maybe I was too generous when I checked all the electrolytics and passed about half of them as good. A failure rate of 50% (at best) is pretty awful. If I had the right parts on hand, I'd be tempted to shotgun the rest of 'em. That's a crude approach, but you can't reach anything with a scope probe when the TV's assembled, and I can't see building custom board extender cables that I'll never use again.
Phil Nelson
