I have an Insignia (rebadged Osram-Sylvania) 19" flat-panel HDTV. The set supposedly has stereo sound, as it has an MTS/SAP decoder. However, the two puny speakers mounted on the back of the set do not do justice to the TV's stereo capabilities. I have two Infinity brand computer speakers from my old Win98 system, and would like to use them with the TV, but I am wondering if there will be an impedance mismatch if I connect them to the set's headphone jack or if I would be risking damage to the set's audio output stages.
![]() Thanks in advance.
jr |
Time to look for an amp, me thinks.
jr_tech and ElectronicM:
Thanks much. I figured it was something simple like that. My next step will be to connect the TV's audio output jacks to my stereo system, which has much better speakers (6" woofers, 3.5" tweeters and powered subwoofers). I read here, in response to the first post I made regarding connecting my TV to an external sound system, that connecting the set's audio output this way will work as long as the TV audio is kept low, so as not to overdrive the stereo's audio inputs.
I suspect that your tv has a pair of standard analog red/white marked RCA audio output jacks on the back or side, that will provide the appropriate level to drive your stereo system "aux" input. On my S0ny set there is a menu option that sets the analog audio outputs to a "fixed" level or "variable" level controlled by the tv's volume control. Your set may have such an option, or perhaps two sets of jacks, or not.
jr |
