Old 09-04-2011, 07:50 PM
benman94's Avatar
benman94 benman94 is offline
Resident Lunatic
Urgent question about tube testers.
I have two options available to me, and I need to make a decision quickly. I can either purchase a Hickok AC-51 in beautiful shape that costs only $90, or I can purchase a Hickok 800K in rough shape (possibly quite screwed up) for $210. Which is the better deal? I know there is more data out there for the 800K (really just a re-named 600A), but I can't imagine that building an adapter for 9 and 7 pin mini-tubes would be that hard. Tube data (and settings) could easily be created for the AC-51 using manufacturer spec sheets for each tube. Any thoughts on this would be greatly appreciated. Need some guidance here . . .
Old 09-04-2011, 09:01 PM
Tough call. I'd go for the 800K in a second if I new for sure it was repairable without spending a whole lot. The AC-51 is a pretty early tester and might be more trouble than it's worth to create adapters and such. I've seen Hickok I-177s go for about the same amount on ebay in good condition that support more tubes.
Old 09-04-2011, 09:10 PM
benman94's Avatar
Resident Lunatic
I just don't know which to go with. Both seem like quite a gamble. As I understand it, the only real difference between the 9 and 7 pin minis and other tubes is the fact that they have a different base style. The adapter would really only be switching the physical connection, the electrical aspect would remain unchanged. Am I right?
Old 09-06-2011, 02:56 PM
maxhifi's Avatar
maxhifi maxhifi is offline
what do you plan to use it for?
I would not try to mess with creating my own test settings, it's more than just data from the tube manual, there's some statstics in there too.
Old 09-07-2011, 03:48 PM
benman94's Avatar
Resident Lunatic
I scraped together more cash, stretched each dollar to the max, and bought them both . . .
Old 09-07-2011, 04:50 PM
maxhifi's Avatar
i have the old standby TV-7C (C for canadian version made by stark in ontario) which i use for most work
And an eico 667 for compactrons... You might want a couple too
Old 09-08-2011, 06:12 AM
benman94's Avatar
Resident Lunatic
I figured that I might as well have two around just in-case one decides to work against me instead of for me. With my luck that's exactly what will happen too . . .
Old 09-22-2011, 07:09 AM
benman94's Avatar
Resident Lunatic
Great news!
I repaired the 800k, the AC51 didn't need a bit of work. The only problem with the 800K was the line adjust potentiometer. I just cleaned up the contacts a bit and bent the wiper contact back into place. I've calibrated the 800K and it's working wonderfully. Now I have an AC51 that I don't really need. ebay here I come . . .
Old 09-23-2011, 12:21 AM
Cool, I'm glad you got the 800K working
