Originally Posted by wa2ise
Sometimes the failure in a transformer is a break right at the terminal, or the transision from the magnet wire to the lead wire. Left over rosin from the soldering process at the factory can corrode the thin wire over the years, and cause a weak point that opens like a fuse. You might try cutting open the outer wrap on the windings of the bad transformer to see if that's what it is.
Great Wa2ise advice, i have had success with others but not on this one it looks like the break is in deep as i to tried checking for continuity on freashly tinned ends on the winding wire with no good results. However i am relieved
that that transformer i stuck in there seems to be working fine till i find a closer match. (I was able to watch wheel of fortune and the price is right without have a incling to play with the height and linaritey controls)
