Dave-
Thank you for that clear description of how this type of remote control system works. On my set, there is a spot on the back panel where the remote control on/off switch is labeled, but the switch itself is not there (nor is there a mounting hole). This set does have two other switches on the back: A "fast warm up" on/off switch (that was off when I got the set, probably helped the CRT live longer), and a "sepia tone" on/off switch (that would change the color temperature, I am guessing?).
