Old 08-27-2011, 03:36 PM
jpdylon's Avatar
jpdylon jpdylon is offline
<-- sucker for old sets.
Look on the FP-746 "mode control" board
You should have heater voltage (between 2-4v outer pins -ac or dc on the flourescan) and a negative voltage around -30vdc to drive the grid (check pin53 on IC 102). Often times the grid voltage goes missing due to a failure in the regulated supply or IC.
Also check to see that you're getting +5 and -5v regulated, and that the 8mhz clock is running on the display processor (pin 5,6 IC102). Otherwise the display mode controller won't work and you'll get no display either.
Machine works otherwise?
Jordan
