Old 08-17-2011, 08:53 PM
rjag46 rjag46 is offline
vizio E320-vl
Just purchased used verry little. No remote, Works but it,s in the 480 dpi mode. Would like to get it in 720dpi mode. Is ther any way to do this with the side buttons ???? Also is there any way to program my cable remote even though i dont have a remote for the tv ??? thank,s for any help
Old 08-17-2011, 09:12 PM
While I'm not familiar with this particular set the resolution should be dependent on the source not the TV.
If you are feeding it a Standard DVD through the Component inputs then 480 is what you should get as that is the DVD standard, a Bluray disc through the HDMI will output 1080p, as far as I know there are no settings on the set itself that will change this.
The manual for this set is available here:
http://www.vizio.com/e320vl.html#support
Old 08-17-2011, 11:03 PM
vizio
Thank,s for the reply
