I just checked the horizontal with a strong signal from a DVD player and the much weaker signal from my in-house transmitter. It locks fine either way, with plenty of stable area between the ends of the range where you lose sync. Possibly the locking range is a little wider with the strong signal.
Turning the brightness up and down definitely makes the image grow and shrink. Since I've ordered the 20-meg resistors, I'll go ahead and replace those when the time comes. I could try another 1B3GT tube, as well. The TV is watchable in the meantime. Phil Nelson |
So it uses 1B3s instead of the 8016s shown in the print?
Doggone li'l set gives one the warm fuzzy-wuzzies. Cabinet-wise it's just painfully cute. And circuit-wise it's got such novel circuits and they seem to work really well. |
It came with 8016s, one of which burned out. My book says a 1B3GT will sub for 8016, and it works fine.
Phil Nelson |
By golly you're right, they will sub. I never ran into an 8016 before.
Still trying to visualize how the 6L6 circuit generates a sawtooth rather than a sinewave. Maybe some of the mavens of the deeper mysteries could offer some insights. oc |
They label the 6L6 "horiz osc," but perhaps it only does output. In an old Milton Kiver book, I found a circuit (first scan) very similar to the one in the 661-P's horizontal/AFC subchassis (second scan). They both follow the general scheme shown in the 661-P functional diagram (third scan).
If I understand correctly, the sync signal arrives at the 661-P's horizontal/AFC subchassis through pin 3 of the adapter plug. One half of the 6SN7 amplifies the signal, which is compared by the 6AL5 to the output of the 6K6 local oscillator. The 6AC7 control tube corrects the frequency. The signal passes to the second half of the 6SN7, and then to the 6L6 output tube through pin 7 of the adapter. Or something like that. In any case, my scope shows a sawtooth at pin 2 (plate) of the 6SN7, which goes to the grid of the output tube. Not the hump-and-peak waveform you get in a synchroguide circuit, but it makes a very stable picture, all the same. Kind of a bare-bones system, otherwise: no damper, no horizontal linearity control, no drive control. The linearity isn't great, but I'm not going to worry about that until I've worked on the HV level and width some more. Phil Nelson Last edited by Phil Nelson; 07-26-2011 at 07:28 PM. |
Hokay. Now it makes a lot more sense. What threw me was the 6L6 being designated "oscillator". So i hadn't bothered to eyeball further back into that H.sync subchassis. Turns out it actually uses a pretty decent phase comparator circuit, rather than "direct injection" of sync into the 6L6 as i first thought.
But still wondering how the flyback is kept from ringing without a damper.From the FWIW department, here's a few thoughts pertaining to the HV.. The three 680K 1W resistors in series sure look to be a post hoc engineering fudgery to limit the HV. As mentioned before, they form the lower leg of a voltage divider. The capacitive reactance of the 500pf 10KV cap forms the uppermost "resistor" of the string. If t'were me, i would open the lower string and insert a fourth resistor and experiment with its value, starting with 680K 1W. Finally, if it looks to be warranted, maybe open the string entirely and see what the HV does. If the HV still seems a little "soft" (bloomy), i would first try a 680K 1W across the aforementioned cap and then experiment with values, to see if it'll stiffen the supply up (ie., give it better regulation, making the pic less bloomy). And those four 20 meg resistors in series, totaling 80 meg, serve no obvious function other than to bleed the charge off the CRT when the set is turned off. They could be dispensed with altogether (IMHO), as most sets never used a bleeder at all on the CRT anode. oc |
Phil Nelson |
