Old 07-17-2011, 06:18 PM
vts1134's Avatar
vts1134 vts1134 is offline
Looking For Time
Hokay, how about checking the video detector diode (M4). While you got one end clipped loose, turn the set on and with a clip lead, intermittently short the grid of the 12AU7 1st video stage (V6) pin 2 to ground. Try this with the contrast control at both ends of its rotation. If the two video amp stages are working, there should be some very robust flashing of the raster.
Following this test gave me no no changes in the raster at all on either end of the contrast adjustment.
Old 07-17-2011, 06:49 PM
Originally Posted by vts1134 View Post
Following this test gave me no changes in the raster at all on either end of the contrast adjustment.
Doggone. Now this may sound like a dumb question, but are the heaters in the 12AU7 video amp tube (V6) lighting up? It has two heaters. For that matter, are there any other tubes in the chassis (other than the 1X2) that are not lighting up? In know, dumb question but it has happened to me more than once. Chased a problem around in circles and it was a cold heater all the time.
Old 08-07-2011, 07:06 PM
vts1134's Avatar
Looking For Time
Decided on a second push with the Monarch. I performed OC's test on the video stage mentioned in post #267 again just to make sure I was doing it correctly.
You can see M4 disconnected in the upper right hand corner of the picture and the clip lead on pin 2 of the 12AU7 towards the middle.
The test produced no results.
This is a picture of the 12AU7, lit up like a Christmas Tree. All other tubes in the set are also lit.
I've also checked the voltages on several of the tubes including all of the video section. What I've noticed is that with my input voltage at 117vac my B+ is running around 15% high across the set, but it is getting to the correct pins. I have not checked the voltages on the tuner tubes. Measuring them from the bottom of the set is impossible so I will need to acquire some extenders.
I'm going to bring some new tools to the party to help the second push along. I'll have a scope, and a video generator tomorrow. I'm not sure these will help in my current campaign, but they're there if needed.
I hope all of you who have been helping me along are up for a second push .
Old 08-08-2011, 02:03 PM
Onward! Hey. Give a holler when you've got the 'real' test gear in hand. I was gonna suggest the 'quick & dirty' method of signal injection using the 6V heater supply like you did earlier for the vertical. But with a proper signal genny you can attenuate the level as you work back stage by stage.
Since you've verified the plate voltages on the 12AU7, have you checked the three peaking coils (L10, L11, L12) for continuity? And how about the detector diode? What's its forward/reverse readings on the ohmeter? Not shorted is it?
oc
Old 08-08-2011, 06:39 PM
vts1134's Avatar
Looking For Time
oc
The heavy hitter test gear will take a few days. I have to order a probe for the scope.
The peaking coils L10-13 all read at or close to spec. The diode reads .3v drop across it.
One thing I did notice after reading all of the voltages on the video stage tubes again. Pin 7 on the 12AU7 was the only voltage that was a good bit off of spec. It is supposed to read -.2vdc, it actually reads -.57.
