I have an RCA jig that uses an 18v tube. At some point the original crt was replaced with a used GE, probably out of one of those awful CE/C2 chassis sets. Well, if that will work, any delta gun from the 70s should suffice. One repairman I met had a roundie jig at the back corner of his bench. When it became too obsolete he built his own modern unit by taking a BPC 25" set with a bad chassis and wiring it up.
Bryan |
