Old 07-12-2011, 06:09 PM
kvflyer kvflyer is offline
Last night, I took the out the first of three large electrolytic capacitors and stuffed it. Today, I stuffed the other two. I also replaced a 4 MFD @ 450 VDC capacitor that was on a board. It tested open.
Replaced the fuse holder so that it will accept the regular type of fuse instead of the odd-ball bayonet type. It is supposed to have a 3.5 Amp fuse. I put in a 3 Amp fuse because I didn't have a 3.5 Amp and it didn't blow. I consider that a good sign
Brought it up to 65 VAC with a variac and saw the filaments of the CRT light. Then, within the next 2 minutes, I brought it up to 117 VAC. It was drawing about 280 watts which is less than what it says on the back so I suspect nothing shorted. No stink, no smoke and I got a raster. It obviously has problems in the vertical section. The height and vertical linearity have some affect on the raster but as you can see, the linearity is way off.
All that I have done is to just clean a little and install the yoke and convergence stuff on the neck, power up.
The good sign is that I have a raster and both vertical and horizontal sweep. Don't know if I will have time right now to continue. But I wanted to get that dead 21CYP22 CRT out of it and put the "New" one in so that it didn't get broken. This is the very first round tube color that I have worked on since the 60s. Hope to get it going and watch Bonanza in Florida. I have done several black and white sets.
