  #37
Old 07-08-2011, 01:25 AM
here are photos of how I used a CTC-7 mounting ring and some hardware store parts:
http://www.flickr.com/photos/4200284...7627018247265/
That is a nice mount for the CRT. Did you use the CTC-5's original yoke, and if so, how did you anchor it since it normally is held by the plastic shroud? I once worked on an early color set that had had its 'AXP replaced by a 21FBP22, and the (original) yoke was basically loose on the neck. I made a bracket that was suspended from under the top of the cabinet to hold it in place and allowed its position to be adjusted.
