Here is the bad news: The 21AXP22A CRT has open filaments.
The CRT appears to be the original, made in the 13th week of 1957 based on the label on the CRT connector. Well, I will at some point go looking for a usable CRT for this set. It is a gray-face type (as may be all AXP's?), but I remember seeing a discussion that some newer ones (early FBP's?) were also gray. I know conversions were done with glass CRTs, but I would not do that on this set unless it was a completely reversible (and ideally, invisible) process. Have any of you done such a task?
