Old 06-30-2011, 04:59 PM
use a HV probe to monitor the CRT anode voltage
is the HOT red plating? wiggle the HOT and the horz osc tubes. hold a neon bulb near the plate cap of the HOT (I have one mounted to a small plastic stick).
I would pull the HOT plate cap off, check for B+, if that checks then I would put it back on and check the HOT grid for about -50v, screen voltage of around 150v. Also check the cathode current of the HOT.
This is where a tv analyst like a B&K 1076 comes in real handy.
Old 06-30-2011, 05:03 PM
you cant check the focus stick like a reg diode. You can just check the focus pin of the CRTwith either a meter like a simpson 260 on the 5kv setting or just a reg HV prob, the same as used in the CRT anode. Check to see around 5kv
Old 06-30-2011, 05:09 PM
fsjonsey's Avatar
fsjonsey fsjonsey is offline
Living The Draper Ethos
The HOT is not red-plating, and has a mild blue glow. I don't have an HV probe right now, but will borrow one from a friend. Neon lamp lights near the plate cap of the HOT.
Old 06-30-2011, 05:13 PM
I would try a new HV rectiifier tube, assuming the HV is not present.
Old 06-30-2011, 05:15 PM
fsjonsey's Avatar
I'll give that a shot, though I just replaced it with a NOS one last night.
Old 06-30-2011, 11:11 PM
fsjonsey's Avatar
Bingo. The "new" one i installed yesterday must have been a dud.
