sweet. cool cabinet. are the reds weak or is it just the programming (looks a bit weak to me)?
It's the lighting and my iPhone camera. CRT tests strong on all three guns.
Well, I have a problem. Went to turn on the set this morning, and a raster never appeared. I can hear some HV whine and audio, but nothing else. The set played fine all last night. Where would be an obvious place to look for a problem like this? I checked the HV rectifier, horizontal output tube, and damper, all tested fine.
Can you hear the high voltage "crackle" when it comes up? If so, look for the video output tube and see if it is lit. I have a similar chassis, different model that gives a nice picture.
Also, check your focus rectifier. I am not sure but on some sets no focus voltage can cause no raster. |
use a HV probe to monitor the CRT anode voltage
is the HOT red plating? wiggle the HOT and the horz osc tubes. hold a neon bulb near the plate cap of the HOT (I have one mounted to a small plastic stick). I would pull the HOT plate cap off, check for B+, if that checks then I would put it back on and check the HOT grid for about -50v, screen voltage of around 150v. Also check the cathode current of the HOT. This is where a tv analyst like a B&K 1076 comes in real handy. |
you cant check the focus stick like a reg diode. You can just check the focus pin of the CRTwith either a meter like a simpson 260 on the 5kv setting or just a reg HV prob, the same as used in the CRT anode. Check to see around 5kv
