Old 06-27-2011, 09:02 PM
Regarding C21, I'd install a 20mfd electrolytic as Riders indicates. Sams shows the same value for that cap and does not indicate any alternates.
If an S bend moves slowly up the screen, I'd suspect a 60hz filtering problem. If you have a stationary bend (which may move or get worse or better with horizontal adjustments), that may be a sweep issue.
You're correct, audio is picked off at the video amp, so sections upstream of that are working reasonably well (at least well enough to pass audio).
You may be closer than you think. Sometimes just one or two funky sweep components can mess up the picture a lot.
Phil Nelson
