Old 06-16-2011, 01:53 PM
IsthmusTV's Avatar
Hi ctc17,
Thanks for the reply. That's what I was wondering, too. I hate to do a recap if it's not necessary. The cans don't get warm but there are some issues with the picture that might be caused by the power supply: Both the height and width are inadequate (even after tube substitutions) and there is a ripple in the picture that drifts slowly upward. Also, there is a really annoying hue shift that coincides with this ripple. I have subbed most tubes, but not all, so it could still be a tube issue or a leaky cap elsewhere.
Also, I suspect that the 6HS6 HV regulator may be weak, even though it tests OK (I don't have a sub for it). If I turn the brightness up too high, the picture dims and begins to fade away. I have tried two different HV rectifiers. I haven't attempted to measure and set the HV yet, though. I know that this set has HV regulator issues but I haven't heard what that translates to in terms of performance problems.
-Clark
