Old 06-14-2011, 10:28 AM
Microtrol's Avatar
Microtrol Microtrol is offline
Finally got a bit of time on the porthole and did a slow power up with the crt and got a raster at around 80 volts. Hooked up my vcr and did a little adjustment and got the picture up and running. The vertical size pot is bad as you adjust it up around mid range and the screen goes to a thin line and just past that the picture expands to super size. Rang out the pot and seems to have several dead spots so it's gonna be replaced. Overall the brightness adjustment is at about 1/3 up in the dark and the crt provides a real bright picture so guess i got lucky on this 16gp4. Now for the analyst and check for other problems.
You are where you want to be
