Old 06-11-2011, 02:25 PM
Originally Posted by VintagePC View Post
If that magnifier is too cloudy/yellowish, this might be the first set you have to give an oil change to! Looks like yours is filled with cooking oil from the colour
Usually they're filled with mineral oil. If it's meant to be changed, there should be a drain screw/plug somewhere.
There is a screw plug on the magnifier. I hope that yellowish color is just on the outside surface though - changing the oil sounds veeery messy.
Originally Posted by TerrySmith View Post
I hope you fix that one, it's nice to see the worst condition set restored!
FWIW,the 6AX5GT is the same pinout as a 6X5 and a lot more robust. If your power trans can handle .4a more current it should work fine!
This set calls for a 5U4 and a 5Y3. I found two 5U4s in it
I looked at the tube location label and it shows a two tube tuner. I never had an Admiral that old. Also, all the power supplies I had, had a 6X5 rect. in the audio supply.
Yes, a 6AG5 RF amp and 6J6 osc. / mixer. Sure looks like it's been replaced though. I wonder what was wrong with the original tuner
