Old 06-09-2011, 04:11 PM
zenith2134's Avatar
CTC-120 ColorTrak
recently acquired a few tv's and this is one of them.
It's a 1984 model, 19" (19VLNP22, RCA) with the LED readout tuner/keypad but a hard switch for mains power and volume. (non remote set)
Very good picture. The greyscale/kine. bias was slightly off but it looks awesome now . I am actually a huge fan of 80s RCA colortraks (from about ctc-89 to 140).
Only issue with this one is the tuner module..it has some video noise in the form of waves (sound getting into the picture) until it warms up. I had this happen on a ctc-97 with a similar MTT module box...had to reflow tons of tiny connections inside it and also clean up the ground-plane wiring and stakes on the IF subboard.
Somewhere in the net there was a bulletin saying that the multi-section can capacitor at the back of the 120 chassis has to be changed out. Apparently, one of the sections gets excessively leaky.
Pics soon
Old 06-09-2011, 04:20 PM
I've resoldered a lot of loose connections in the tuner/control module in those sets. I've also replaced a lot of those filter cans. There is a variable cap in the chroma circuit that will either fail or fall out of adjustment, causing no color. Otherwise, these sets were very reliable.
Old 06-09-2011, 06:41 PM
zenith2134's Avatar
Yep, it is the first 120 i've owned. I liked my ctc-117a the best from this era,, it was a very nice colortrak model with o.s.d.
That being said, this one has just as good of a picture.
Old 06-09-2011, 08:53 PM
In the CTC121, there's an adjustable coil in the IF strip that one can tweak to get rid of the sound getting into the video. The IF is mostly a SAW filter, but there was a coil or two that could be adjusted. I don't remember specifically which coil it was though. The CTC120 may use the same.
Old 06-10-2011, 06:51 AM
Findm-Keepm's Avatar
Followin' the Rules...
.....that would be the discriminator coil, L201. Common problem with those RCAs. Components age, and things get to the fringe. A slight tweak brings it back to center. Check/align when it's warm, then check from cold the following day.
Cheers,
Brian
USN RET 22YRS (Avionics/Cal)
Old 06-10-2011, 01:12 PM
zenith2134's Avatar
Thanks for the tips about that chroma coil. I seem to remember a local tv tech mentioning how if it was a smoker's set, the coil would get clogged with nicotine or whatever it is, and cause intermittent color.
