Old 06-01-2011, 01:42 AM
Penthode's Avatar
Penthode Penthode is offline
I have had success chipping a bit of the glass away from the lead. I could then get enough of a stub to wrap a wire around it. I do not want to recommend this, but I was desperate and it worked.
I would also using a thinner gauge wire or even a stranded lead on the stub. It will allow more flexing and put less stain on the joint as you slip the wire in the socket.
