Old 05-17-2011, 12:05 AM
Microtrol's Avatar
Microtrol Microtrol is offline
Blonde Port Started
Finished up the teletone and now off to the Blonde port hole set. Just a few pics of the disassembly of the unit and everything looks fine except the black waxy insulating material on the flyback is cracked on some of the pieces have fallen off. The unit rings out ok and wondering what I can use to either hold the remaining stuff on or replace it, any suggestions.
You are where you want to be
Old 05-17-2011, 06:45 AM
VintagePC's Avatar
Tube bug got me 05/2010
People here tend to coat the flybacks in RTV silicone, but any other material with a high resistivity/breakdown voltage should do the job.
You're probably best removing the loose stuff before you put anything new on it, to minimize the air space around it - and then really work the stuff on so it's there's as little air as possible around the coils.
That should prevent any arcing from happening as a result of the cracked outer tire.
Old 05-17-2011, 10:02 AM
Bill Cahill's Avatar
Super Moderator
Post
It has been found that some of the silicones, and, other types tend to be corosive, and, reccommend against them.
Bill Cahill
Please join my forum.
Old 05-17-2011, 10:15 AM
Microtrol's Avatar
I'm curious, could the unit be coated with corona dope?
Old 05-17-2011, 10:15 PM
get the sensor safe rtv at the auto parts store. acid free.
Old 05-18-2011, 12:02 AM
It looks like most of that wax will flick right off if you warm it with a heat gun. That's what I did recently when recoating a Philco flyback. I had meant to melt it off like liquid, but the stuff just started falling off in big pieces when it got warm.
This thread has some photos and a couple of recommendations for recoating material. I used sensor safe RTV. Eric H recommended some space age stuff from Aervoe.
Phil Nelson
Old 05-18-2011, 08:33 PM
Yours looks like my 24H20/24H21 that still works with only tubes and a couple of papers that were replaced in the 1970's. Does yours use a second audio/power chassis?
Old 05-18-2011, 09:00 PM
Microtrol's Avatar
Tom,
It has the second chassis for the power audio. Portholes are nice sets and hoping to get her running in a couple of months as I have a mahogany unit coming at the end of the month.
Brandt
Old 05-29-2011, 02:15 PM
Microtrol's Avatar
Talking
Well, re-coated the flyback with the sensor safe material. Looks like more of a bad cupcake frosting job but there are no voids on the inside. Currently recapping the chassis and going to replace the 6 sand power resistors as i have never had good luck with them working after such a long down time. The other mahogany porthole showed up yesterday and will post up some picks later on.
Old 05-29-2011, 07:37 PM
JCFitz JCFitz is offline
Was there a thread with pictures of the cabinet? I just picked up a blonde porthole combo myself.
Old 05-30-2011, 12:28 PM
Microtrol's Avatar
Here's the link
http://videokarma.org/showthread.php?t=250578
Old 05-30-2011, 12:53 PM
Originally Posted by Microtrol View Post
Nice!
Old 05-31-2011, 07:25 PM
Microtrol's Avatar
Finished with most of the paper caps and waiting for the new power resistors to come and I'll finish off the electrolytics.
Old 05-31-2011, 09:11 PM
CoogarXR's Avatar
CoogarXR CoogarXR is offline
This is a dumb question, but how did you get the CRT off? When working on my 12" porthole, I just lay the chassis on its size and clamp it to the bench (with the CRT attached). My 16" though, I am afraid that it might be too heavy or whatever. I haven't worked on that one yet. Can you take the CRT off without screwing up anything alignment-wise?
Old 05-31-2011, 09:27 PM
Microtrol's Avatar
Well I'll see if I screwed up some alignment but after marking the tube in the yoke, I removed the high voltage springs, then the front support and insulator ring and supported the bottom of the tube with some foam. The tube (16gp4 metal tube) in my unit was very light compared to say a 12lp4 unit and it slid out ok but still was white knuckling it cause of the very long neck.
