Old 05-30-2011, 10:10 PM
JCFitz JCFitz is offline
Well I brought it up to full line briefly. There was sound from the tuner and the horizontal stage is definitely working but no high voltage. Tried another 1B3 I know was good.No go.The 4.7ohm resistor is open under the socket according to my continuity tests. Anybody ever have to pry open one of these arrangements? It's a metal holder mounted on top of the doorknob. Wish I had a solid state replacement lying around to get around this to see what I got. If it works otherwise this resistor may be why it was retired.
It had to be brought to full line to wake up the IF and tuner stages so there's some weak tubes or that 5Y3 is causing that.It only brought up to 40 both sections on the scale of my B&K 747. So I need a 5Y3 for sure.
Old 05-30-2011, 11:35 PM
Went out looking in my used tube stash. Knew I had saw a solid state rectifier sub there a while back. Found it. It's for a 3DB3 but I figured I'd try it and it worked. Got a vertical line which increased a little as it warmed up. There is no sync and the picture is best when the sound is tuned out(What else is new...lol)
After a few minutes there was static in the speaker and the raster was jumping around. The 6SN7 in the vertical stage was sparking inside. Went and got a 6SN7 and got a half a picture this time. Getting better. I'm gonna drag out my B&K 747 and see what culling out the bad tubes does before I stop powering it up for recapping. I found a strong 5Y3 but it still takes a minute or 2 for the IF and tuner to wake up at full line voltage. Just a raster at 110v.
