Old 05-30-2011, 05:50 PM
Glenz75's Avatar
Glenz75 Glenz75 is offline
NZ Vintage TV Collector
Good luck with salvaging that CRT. I'd be very nervous if I had to grind away at the glass to get that broken leg a bit longer..... Nice set by the way looking foward to your restoration adventures on it! ...Cheers
Visit my Vintage TV & Radio Page - http://nzvintagetvradio.blogspot.com/
My YouTube Link - http://www.youtube.com/user/glenz1975?feature=mhsn
Old 05-30-2011, 06:12 PM
I know I have read about someone (Eric H?) who at least thought of filing or grinding out enough glass to expose a broken lead. Whether he actually tried it, much less succeeded, I don't recall offhand.
Wish I was better friends with my dentist. Bet she could do it in no time, and she's got the gear: water-cooled instruments, super magnifying goggles, etc.
Phil Nelson
Old 05-30-2011, 08:53 PM
Phil, is that lead busted off absolutely flush with the glass? If there were as much as 1/64" of a stub sticking out, it should be possible to solder to it. I would take a single strand from a lamp cord and bend it double, then hook the U-bend over the stub and solder it.. after first cleaning the stub thoroughly so it'll take solder readily. The resultant lead would consist of two strands of lamp cord wire - easily manipulable without straining the connection. oc
Old 05-30-2011, 09:08 PM
If the current draw on that pin is really low in normal use, you might get away with some form of conductive paint or epoxy.
Or solder a thin lead to the flush broken off lead area, and epoxy over it to keep it from breaking off.
I'd do it while you have the CRT set up on that test setup, to be sure you really did connect.
Old 05-30-2011, 09:46 PM
There really isn't a stub at all. If anything, the wire end may be slightly recessed in the glass. It's hard to see, much less reach.
I tried soldering single copper strands to the existing leads, just to see how hard it will be to attach guide wires. I scraped the old leads shiny and tried to tin them beforehand, but had a heck of a time getting solder to stick at all.
Is there something else I can do to improve adhesion? If not, I see no chance that I could solder a strand to that stub. Maybe cleaning the stub shiny and fastening a lead with epoxy is the best I can do.
I'll need to redo the test strands, in any case. They're only about an inch long. I realized too late that it'll be easier if they're several inches long, so you can bend and insert each guide wire separately, rather than try to line them up and insert all at once.
Phil Nelson
Old 06-01-2011, 09:31 AM
ohohyodafarted's Avatar
Bob Galanter
Phil Nelson
Phill, I have done the glass grinding successfully. I did it on 3 leads of a 21axp22 that I was trying to salvage. The opperation was a success but the patient died (the crt was very weak) I eventyally took the crt to Scotty for rebuild and it incured catastrophic failure of the face plate in his oven along with another tube, but that is a whole nother story.
What you need for the grinding on the crt button is diamond impregnated burrs to put in your Dremel. The diamond burrs will grind glass very easily. I purchased an entire kit assortment on ebay and they were not at all expensive. Standard carbide burrs will NOT do the job. Don't even attempt with anything less than diamond.
After you expose some of the wire it will be difficult to get solder to stick. I took a small patch, of Chemtronics solder wick and placed it over the wire stub and saturated the patch with solder. Then I tack soldered a fine wire lead to the solder patch that was stuck to the wire stub.
You only need to expose the tip of the wire, perhaps .010" I would not risk going much farther. You will not be able to attach a wire directly to the stub because the glass will sink the heat from the wire and you cant risk heating the glass much because you could crack the glass if it gets too hot.
John Folsom has also accomplished wire attachment using a silver epoxy compound. Because you are attaching to a grid wire, there is very little current flow and the silver epoxy is conductive enough to work in this situation. Being as your issue is a grid wire, this epoxy method may be your best bet.
Good Luck!
ME http://AntiqueTvGuy.com
Old 06-01-2011, 10:46 AM
John Folsom's Avatar
The silver filled epoxy worked well on the K, G1, G2 and convergence leads on a 15GP22. I obtained this tube with a smashed base and the 4 wires broken off flush with the glass. I put a little collar around each broken wire, and filled the collar with epoxy and inserted a length of very fine flexible wire into the top of the collar and let it cure in place.
Then all the CRT leads had long pigtails attached and threaded into the base pins and the base slid back into place, soldered, and the excess pigtails cut off.
The 15GP22 tested good after the operation was complete.
Sadly, several years later, when it came time to use the repaired 15GP22 in a set, it had the dreaded purple glow.
I speculate that the CRT was damaged when the base was broken, but it could also have been a spontaneous leak at the glass-to-metal joins at the ultor, or the ultor seam weld. If our first shipment of 15Gs to RACS is successful, this tube will be cut open and leak checked.
The only down side to the silver filled epoxy approach is that the epoxy is quite expensive, and might not be justified for a "common" tube like a 10BP4.
Sorry, did not intend to hijack the thread....
John Folsom
Old 06-01-2011, 11:41 AM
Thanks, that gives me some good ideas. The silver epoxy sounds easier and safer than grinding. While the 10BP4 is a common tube, it would still cost something to replace, so anything less than replacement cost is a bargain.
I wouldn't be so gung-ho if it had tested weak, but the tester needle jumped right up into the Good zone, no wake-up period required. So close . . . just one little wire!
Phil Nelson
Old 06-09-2011, 07:22 AM
jeyurkon's Avatar
jeyurkon jeyurkon is offline
Phil Nelson
The silver epoxy I use at work costs far more than a 10BP4. However, I've seen small packets of silver epoxy for repairing car defoggers that might work and are inexpensive.
John
