Old 05-27-2011, 10:48 AM
Originally Posted by vintagecollect View Post
pwm motor controls are common, it looks pielock uses a foreign pre made jobber. The motor looks 12v w/ a high torque gear box. No reply yet from him. Looking to get info on motor at least, is his wheel watchable w/out a phase lock? Waiting for feedback.
hey tv nut,
WAS you mech set watchable w/out sync? did it go out of sync a lot? Is a color wheel viewable w/out red sync pulse, HOW often would it go out of sync?
Mech TV practically impossible to view without sync. Sort of "look, there's a picture - oops" as you constantly adjust. Peter Yanczer has shown some systems where camera and monitor both used synchronous motors running from the AC line. These were not perfectly stable, but constantly hunted back and forth a bit. The servo does a much better job.
For Col-R-Tel, the hunting from a synchronous motor would be tolerable, I think, but a synchronous motor (60 Hz line) would have a different problem because vertical is 59.94 Hz, so the phasing would continuously drift over about a 17-second period.
