Old 05-25-2011, 11:11 PM
Penthode's Avatar
Penthode Penthode is offline
Originally Posted by init4fun View Post
A couple of things bother me . First , the supplied spare tubes , , , , I see a rather newer looking octal there . And is that a mounting for some kind of Tuning Eye setup , , , I dont see one on the tv . Well anyway , beyond the spare tubes , Wont being missing the speaker be a major hit to its collector value ? Yea , Im sure a suitable substitute most certainly can be found , but points off for not being 100% original ? Also , how hard would it be to find/manufacture the broken knob/switch ? .
Course , none of that really matters , , , its at $3150 with 4 days left , , I'll bet it hits 5K easy .
I remember the 707 from some years ago. I recall the following details on this set:
The octal valve (tube) base was introduced to the UK about 1937. The Marconi 707 uses a KT63 for the frame (vertical) output and line (horizontal) output. The KT63's US equivalent is a 6F6!
If I recall correctly, there are four octal tubes in the 707: the frame oscillator, frame output, the line oscillator and the line output.
The 707 is an early superheterodyne for vision and sound. When this set was built, Alexandra Palace broadcast the BBC vision signal carrier (45MHz) with full double sideband modulation. The AM sound carrier was at 41.5MHz. In the Model 707, the sound IF (for AM sound) was 4.5 MHz and the vision IF was 8MHz. The earlier Marconi EMI TV models were TRF vision and superhet for sound only.
