Old 05-15-2011, 04:31 PM
Originally Posted by Aussie Bloke View Post
... if you are referring to the dark vertical burn line at the left end of the picture, that is actually a common artifact with image orthicon cameras (colour and B&W) and can often be seen on any program shot with them... I actually wonder why IO tubes have that artifact myself?
The vertical bars on the left edge are yoke ringing in the horizontal deflection. If you look carefully at the music festival clip, you will see horizontal non-linearity (alternate stretching and compression) in that area as the camera pans. The scan velocity is being modulated, which affects the sensitivity and produces the darker/lighter bars on bright scene material.
