Old 05-07-2011, 06:32 PM
Adam's Avatar
Adam Adam is offline
As far as build quality, I think anybody ever topped what you see in the old Tektronix 500 series o-scopes.
Old 05-07-2011, 09:18 PM
ggregg's Avatar
ggregg ggregg is offline
I'm thinking along the same lines as Chad. We've come to expect cheap electronics, cheap everything practically. Much of today's stuff isn't even really designed to be serviced at all. You can buy a DVD player for $39. Down the line, if the laser gets weak or goes out, your chance of finding that part is nil and even if you could, it would cost something like $80-$90 probably because the only thing you could get would be the entire assembly. Very few places stock anything anymore. Repair costs exceed replacement costs and it's hard to find good old fashioned repair shops. Best Buy, forget it.
I remember servicing VCR's when they were heavy beasts that usually only needed idler wheels and belts changed, sometimes heads. The last one's I worked on would be worn out after two years of use. The mechanisms would be so sloppy, it would jam up. Mode switches failed all the time, etc. The design was actually much better than the earlier machines but the grade of parts, motors, etc., was so poor, they would not last. But they were one third the price they used to be.
TV's were the same way. Remember the RCA/GE's with all the board shield problems? Never would have happened if the components would have been separate, instead all on the same board. Also wouldn't have happened if some genius could have figured out the metal and plastic don't expand and contract at the same rate when they are hot/cold. Something has to give and it was solder joints which would sometimes take something else out with them. The fix was to resolder all the shields with new flexible solder. But this design became popular because of the lower cost it took to produce it. Today with the new flat screens, it seems to be power supplies that pack up. My Phillips is an older one (2003). I brought it to a tech because I didn't want to mess with it. He went through the power supply and replaced all the caps and diodes, not just the two that failed with stronger parts. He said it will outlast the display and I believe him. He also said the the newer, inexpensive ones are difficult, if not impossible, to get unique parts for and are a bitch to work on.
In the old days, if you bought a cheap radio, you probably paid up to $19.99 for it. Seems cheap but translate that into today's dollars. $100? $150? more? Still seem like a good deal? Any appliance was a major purchase whereas today you can pay more for a movie than for the player to play it on?????
OK, off soapbox, ranting stopped (maybe), sorry if I went a little off topic.
Old 05-07-2011, 09:24 PM
peverett peverett is offline
I also remember GE's cheap TVs in the 1960s, all tubes, including horizontal output and damper on the PC board. Motorola and Philco also started doing this at some point. After a few years, the PC board was charcoal and the TV was unrepairable. Some manufacturers were cheap back then too.
Old 05-08-2011, 12:20 AM
Oh, there was cheap crap sold back in olden days, but you rarely see any of it because 99.9% of it has been tossed long ago. I did find, when we needed to sell my grandmother's house, a really cheapo photo enlarger for a home dark room. Used corrugated cardboard for positioning lenses. Probably sat in the attic, where we found it, forgotten for about 40 years.
The Japanese made really crappy AA5 radios back in the 50's, before they mastered quality manufacturing. You rarely see any of them today.
Old 05-08-2011, 12:30 AM
mbates14 mbates14 is offline
Crown brand? I think i have one. and of course, it doesnt work.
Old 06-04-2011, 04:47 PM
Kiwick's Avatar
Kiwick Kiwick is offline
slave to 3 equines
Another oldtime POS japanese product were those junky portable rim drive tape recorders, they were useless even for speech recording right out of their boxes, and usually failed real quick due to crappy capacitors/motors/mechanical parts and so on...
Yet loads of them are still around, and they're often popping up on Ebay...
Some vintage stuff was also quite unsafe, flame retardant materials weren't used back then, many sets were housed in flammable wood cabinets, AA5 radios and other hot chassis designs often had hot parts easily accessible to the user.
The WORST vintage electric chair of all times would have to be the Italian-made Geloso G255 hot chassis tape recorder from the mid 50s, this thing was insanely dangerous, the microphone socket's ground was tied directly to the hot chassis, you had to use the supplied isolated microphone but it was made of crappy brittle plastic that broke easily and then you got exposed hot parts, also some people were reportedly electrocuted to death when they plugged a regular metal cased microphone into one of these things...
Old 05-08-2011, 10:54 AM
Old 05-08-2011, 12:38 PM
That really takes me back, what a time for the hobby. Top quality gear being sold in there as well (scott, Mcintosh HK). Prices were not cheap like the garbarge you find for sale now and what a huge selection of items being sold. "the shack" has really really gone to the dogs.
Old 05-08-2011, 02:30 PM
TerrySmith's Avatar
TerrySmith TerrySmith is offline
Just last week I picked up a LG 42" plasma TV non-working off of craigslist. Ended up needing the ICM, which is the large module on the Y-sustain board. It was a royal pain in the a$$ to unsolder! Flat screens woudn't be so bad IF they would use better quality components namely CAPACITORS!
Summer of 1980 I stopped by a repair shop that was going out of business and got a 19" Zenith CCII with the 4-lead cap problem and the neck burned off the CRT. I replaced the capacitor an scrounged a 19" CRT from a junk set (not a Zenith) and stuck it in. Convergence was close enough, focus was a little off but had a decent picture! I used it for another 10 years and gave it to a friend who used it 5 or so years more. He gave it back and it was really beat up so I set it outside for another year or two and one day I decided to power it up- and it still worked! I really miss Zenith quality!
Old 05-08-2011, 03:18 PM
I cleaned out a TV shop a while ago and think that I have a couple 2 transistor radios laying around somewhere(If I can find them). I am not sure if they are Realistic brand though. I also have a box of brand new LLoyds AM transistor radios from the 1970s that were in the shop. I have put batteries in a couple of them and they work just fine. Probably not worth anything at all though.
Old 07-05-2011, 09:42 PM
DrRick DrRick is offline
Where did you get the ICM?
I have a 42" LG plasma with a shorted ICM on the Y-sustain board.
QUOTE=TerrySmith;3002706]Just last week I picked up a LG 42" plasma TV non-working off of craigslist. Ended up needing the ICM, which is the large module on the Y-sustain board. It was a royal pain in the a$$ to unsolder! Flat screens woudn't be so bad IF they would use better quality components namely CAPACITORS!
Summer of 1980 I stopped by a repair shop that was going out of business and got a 19" Zenith CCII with the 4-lead cap problem and the neck burned off the CRT. I replaced the capacitor an scrounged a 19" CRT from a junk set (not a Zenith) and stuck it in. Convergence was close enough, focus was a little off but had a decent picture! I used it for another 10 years and gave it to a friend who used it 5 or so years more. He gave it back and it was really beat up so I set it outside for another year or two and one day I decided to power it up- and it still worked! I really miss Zenith quality![/QUOTE]
Old 05-08-2011, 05:55 PM
ggregg's Avatar
Check out pages 8 and 9 for some cheap radios. They go as low as $2.99! That's about $20 according to the inflation calculator. I've never seen a 2 transistor ratio, but I bet they sold a lot of them.
http://www.radioshackcatalogs.com/ca.../1965-a_small/
I was thinking more of in the thirties instead of 1965 but I get what you are saying.
You know stuff has really gone to the dogs when we are talking about the quality of Lloyd's. I know, much it is not too bad, especially compared to what came after.
Old 05-08-2011, 06:34 PM
My clock radio is a zenith 6 tube set with an large ferrite rod antenna with some kind of noise cancelling going on, it has connection to the chassis thru a shielded cable. Great set and very good AM dxing. The chassis is classic zenith hand wiring. The only weak point is the dial string which just broke the other day, but of course an easy fix. It has the built in coffee pot outlet, and a sleep timer so I can plug in a TV or stereo, and have it auto shut off after about 45 min.
Old 05-08-2011, 07:35 PM
Speaking of Japanese AA5's, here is a chassis picture of one
And a similar complete radio
These were not very good.
Old 06-05-2011, 11:35 PM
Dave A's Avatar
Dave A Dave A is offline
The 15GP22 in Radio Shack
I counted 48 different AM/FM radios in the 1965 Radio Shack catalog. Now that would be 48 different cell phones. And don't miss the
"Americana AX-100" amp with 100 transistors and no transformer.
1965 was a time when we were flooded with a variety of economic choices including the good, the bad and the ugly. The bad won. Ugly is seasonal depending the designs showing up. BPC one year, silver the next, translucent next.
Then I went through the catalogs for the elusive 15GP22 and a few others...and they had them! One of few color tubes they ever sold. And not under the Lifetime banner.
1957 $235/$1881 today.
1958 $265/$2121 today.
1959 two different prices but with the same stock number. Also appearing for
the first time are the AXP and CYP at the lower price.
GP $235 and GP/AXP/CYP $128.
1960 $128/AXP only. GP gone.
1961 $108/AXP only. GP still gone. Nothing but BW after 1961.
And in 1961 you could still get that 19AP4 for your DuMont for $23.50. I quit after 1962 as I was too depressed to go on.
Dave A
