Old 04-25-2011, 10:14 AM
Originally Posted by bob91343 View Post
Boards don't generally go bad. Components on them do. So troubleshoot it and repair it.
That would probably be the best action to take. The only time I replace boards is when the original board was severely damaged by lightning, has received severe physical damage, or uses extensive surface mounted components that would make the board impractical to repair with regular soldering equipment.
It's very likely that your board will only need a few low cost components; which, will be MUCH cheaper than a new board, if you can even get the board. When I first started repairing TV's, I'd often replace the whole board. Then, I discovered that I could often fix the old board with $2 worth of new parts. That sure beats $50-$100+ for a new board.
If you still feel like you need a new board; these folks, http://www.pts-electronics.com/home-page/, may have the board or can rebuild your old one.
