Old 03-12-2011, 03:15 AM
I took a DVD player out to the garage and hooked it to the 19" set, it works like new, a very bright CRT, Bright set to about 1/3 Picture about 1/2, Color is great and really good detail.
I was using my Isolation Transformer (also a Sony) since i needed two outlets and couldn't find a multi outlet extension cord.
The 19" set and the DVD player ran fine off the transformer, it's small and it drops the voltage slightly but they ran fine off it.
I decided to see if the 15" set would run using the drop from the transformer, sure enough it does, CRT is very strong on this one too, everything seemed to work but I got no sound from the speaker except possibly a slight hum.
It actually was the Isolation Transformer that was humming and it got loud, resonating off the bed of my truck, struggling with the load the set was putting on it.
The set seemed to be working fine still but it was clearly drawing too much current.
So what do you guys think, bad caps loading it down or bad regulator?
I guess I need to take the back off and see if anything gets hot, I don't want to blow the HOT though.
Here's some screen shots of the 19" set playing "The Mothers In Law" DVD, I might just clean this one up and make it my bedroom set!
Old 03-12-2011, 10:23 AM
sampson159's Avatar
sampson159
i had one of those sonys last year.best picture i ever saw!crt was excellent.it was my garage watcher for awhile.i sold it and am kicking myself!when those sonys were good,they were great
Old 03-12-2011, 07:52 PM
Findm-Keepm's Avatar
Followin' the Rules...
The regulator transistors in those Sonys were a common problem - they'd short E-C, or go leaky B-C, giving you excess B+. Part number is MN8303 (preferred) or use a 2SC2581, and an NTE36 will do as well. Don't over torque the mounting screw when replacing them - the heat makes them expand somewhat and you'll be right back to square one if you torque too much. The driver transistor that feeds the regulator should be replaced as well when you replace the regulator - it'll check just fine, but go open on you, necessitating a call back. Other than that, most other problems were either audio related or bad remote functions - the IR Amplifier chip would short, pulling down the 12V line. OH - Get rid of any yellow glue in the regulator area too - it degrades with heat, turns brown, and becomes quite conductive. They are really good sets - I had a 17" one (KV-1746R) in my den for a few years.
Cheers,
Brian
USN RET 22YRS (Avionics/Cal)
