Old 03-08-2011, 11:39 AM
kx250rider's Avatar
REAL TVs have TUBES!
Originally Posted by rca2000 View Post
On the Oldsmobile Trofeo...the CRT monitor IS a color one--and the tube IS a trinitron, with the touch-plate in front of it, the VIC monitor unit is a LOT bigger and heavier than the Zenith 5" green one you(and I) have lying around, The case says "Sony trinitron" (along with "Denso"), and the tube has the trinitron label--and look--about it. Like the green Riviera monitor--the Desno/Sony one is WAY overbuilt, with a HUGE flyback and heat sinks inside of it--for a 5" color monitor--compared to a normal 5" color set. .
I guess that GM decided to "go one better" when the decided to put a touch-screen computer option on the Trofeo from 89-92, and made it in color and MUCH easier--and more user-friendly--to use. (I have owned 3 of the Riv's over the last 20 years with the green touch-screen, I liked them, but they are NOWHERE NEAR as nice--or as easy to use-- as the color one in my 89 Trofeo is.) GM had even planned for a GPS system on them--but the system was not ready in time(probably due to the shuttle disaster.)
If only the VIC system would have 'caught on " back then--instead of OVER 10 YEARS later .
Now my curiosity is killing me... I saw a Trofeo at the junkyard last week. Not sure of the year, or if it has the touch screen dash... I'm going to go check asap, and I'll harvest that monitor if it's still there
Charles
