Old 03-06-2011, 05:00 PM
maxhifi's Avatar
maxhifi maxhifi is offline
Speaking of video.
When I put a clip lead at X, and use it as an antenna, near the horizontal output section, the following picture results.
The old C121 had very long leads, and the new one shorter leads... I have a feeling placement in the area must be critical, so will spend some effort here.
EDIT - even with the 6AW8 pulled, and the plate grounded through a capacitor, problem still there as always, just not emphasized as below. Also, the problem is still there when the front and rear chassis are separated. I'm starting to wonder if a NOS 6AX4 might be the answer... all of the ones I tried test exactly at the minimum value on my TV-7 tube tester.
