Old 03-02-2011, 06:33 PM
Steve D.'s Avatar
Steve D. Steve D. is offline
Looks like 1951 may have been the transition year between the porthole and rectangular picture tube Zenith sets: TV0832-lrg.jpeg
http://library.duke.edu/digitalcolle...V0832-lrg.jpeg
-Steve D.
Old 03-02-2011, 07:31 PM
ggregg's Avatar
ggregg ggregg is offline
Originally Posted by CoogarXR View Post
Sean- Awesome job on yours! Thanks for the links, I am sure that will help.
ggregg- Nice Porthole (sounds strange to say to another man, lol). Does yours work? One like yours came up on craigslist when I got home from buying mine. If I had space, I'd buy it too
Yes it works kinda. When I bought it, I did some preliminary checks and then plugged it in and brought the voltage up very slowly with a variac. I have a bright raster so my HV section is working and the picture tube seems fine which are the main issues with these. The radio and phonograph both work. I've only bought one old TV that actually "worked" OK when I bought it (1953 Crosley). They all need paper and usually electrolytic capacitor replacement, usually a tube or six, and usually some other parts. I've been working on a DuMont RA-109 all winter that I finally got going a couple of weeks ago. It still needs a little tweaking but the worst is done. Dozens of caps and 5 tubes including a picture tube, which I really lucked out on. Now I'm working on a 10" Admiral and then the Zenith. Good luck on yours. It's a cute little set and you got it at a great price. I paid a lot more than that for mine.
Old 03-02-2011, 08:11 PM
CoogarXR's Avatar
CoogarXR CoogarXR is offline
OK, I measured the resistance on the two CRT pins either side of the socket key, and it showed some resistance, so that's good. Now I have another question- is it normal for the CRT connector to be loose? I can wiggle the plastic part back and forth about 1/16" inch.
Old 03-02-2011, 09:18 PM
CoogarXR's Avatar
I got the chassis pulled out, and setting on my bench. Getting the knobs off was the hardest part!
Now- how do I position this so I can work on the bottom? Any direction I would tip it would put pressure on something delicate... Any ideas?
Old 03-02-2011, 09:36 PM
compu_85's Avatar
compu_85 compu_85 is offline
Procrastination Expert
What was Phonevision?
Old 03-02-2011, 10:04 PM
CoogarXR's Avatar
Originally Posted by Phil Nelson View Post
Are you familiar with the ETF museum in Hilliard? (Just outside Columbus.)
http://www.earlytelevision.org/index.html
Phil Nelson
Nope, I never had heard of that. I am happy to see it's only about an hour away. I will certainly be paying them a visit! Great site too!
Old 03-02-2011, 10:29 PM
Phonevision was an idea that Zenith had, which would have been sort of like cable TV, or maybe even the internet! It never took off, though.
The crt base shouldn't be loose, but many/most of them are. You can use some glue or tape to hold it tight-there are some suggestions on this site somewhere as to what works best. I haven't tried to fix one with glue for a long time. Just be careful that you don't wiggle it around so much. The wires coming out of the neck tend to be brittle and can snap off even with the glass-not good!
The museum is well worth the visit, and there are several VK members scattered around the state. Maybe one could give you a hand with a crt test?
Am I correct that the crt is strapped to the chassis on this model? I will usually place them on their side gingerly, maybe with an old towel under the crt. Make sure the crt is strapped down tight so it doesn't shift when you move the chassis over. On some I have used a pair of clamps to hold the chassis down to the workbench (in my case, and old desk) while working on it. The crt is the main thing you have to keep an eye on-I don't think you will hurt anything else.
Old 03-03-2011, 01:03 AM
ETF is just about the center of the universe for TV collectors. The annual convention is coming up this spring. It's fun and educational -- I have been going for years. You can pick the brains of some very smart & knowledgeable people and the swap meet & auction typically have some good deals on old TVs.
Phil Nelson
Old 03-03-2011, 06:22 AM
cwmoser's Avatar
cwmoser cwmoser is offline
... Now- how do I position this so I can work on the bottom? Any direction I would tip it would put pressure on something delicate... Any ideas?
I predicted that I would need an easy way to mount the chassis when I restored my Porthole TV - so I wanted a comfortable way to position the chassis. I took some strips of wood and made the following:
I used a test CRT in place of my 16" picture tube. In the photo above I used an 8AXP4 tube until I got a picture. The chassis stand I made is bolted to the chassis and allows me to rotate it to a comfortable position to do recapping - here it is rotated to a comfortable position for working on the bottom of the chassis:
I brought in some help to test for out of tolerance resistors:-)
My suggestion is to take lots of detailed pictures of your progress.
Carl
CW
Old 03-07-2011, 09:40 PM
CoogarXR's Avatar
bgadow - Thanks for the tip on clamping it to the bench, worked line a charm! I've owned this thing for over a week and I finally get to see the underside of the chassis!
Now, I think my flyback may be burned up. Remember guys, I don't know what an old flyback is supposed to look like, but I bet it's not supposed to look like this! What do you guys think? Is it shot? If so, anybody got a good one?
Also, one of my "sand" resistors is completely missing it's "sand" coating and the windings are torn up (mouse damage, I assume). How can I find this value?
There's a couple other chewed up mystery devices, but I'll get to those later. Here's the flyback- what do you think?
Old 03-07-2011, 11:20 PM
miniman82's Avatar
First Light: 1952-2011
It's hard to tell with all that crap around it, but it looks to me like the wax around the outside may have just flaked off with time. It's possible to coat flybacks, I used acetate free silicone on one of mine and it worked great.
Evolution...
