Oh yeah. Check vscan to ground onthe left board (ysustain)
This voltage input goes right into the y buffers ( 2 boards on the left connecting from the y board to the screen via ribbon cables. Look at the bga soldered chips. Do any of them have cracks or bubbles? If so most likely shorted and loading down the power supply something fierce. If the smps does not have a protection shutdown circuit ( visually you can tell if it does not if there are no opto-isolators (4 prong dudes with 2 prongs each side) then your power supply is toast. These sonys were most likely manufactured by nec.
