electrode surfaces, and even if you stop the leaking process, continued operation will keep releasing gas inside the tube, and the getters (already weakened by the initial leak) will not be able to cope with all that gas. When the tube is rebuilt, it is heated while being pumped out, and this is done before the new getter is flashed, so that much of the adsorbed gas is removed, and the (new) getter can do its job after the tube is sealed. Regards. |
