Old 03-12-2005, 10:09 PM
polaraman's Avatar
polaraman polaraman is offline
<--1956 300B
Phillips TV find
Been helping clean out a TV shop the last two weeks. Uncovered this little gem today. Decided to drag it home and see what makes it tick. Was excited that it was a tube set. A definite keeper in the collection. Real strange chassis and tuner. The tuner has pushbuttons. The coax cable is cut off on the back of the set. Does anybody know what goes on the ends?
polaraman
Old 03-12-2005, 10:11 PM
polaraman's Avatar
<--1956 300B
Chassis view! You can see the two strands of cut off coax in the botton left of the picture.
polaraman
Old 03-12-2005, 11:42 PM
It looks European, could it be a PAL set?
Old 03-13-2005, 03:44 AM
RetroHacker RetroHacker is offline
Electronics Accumulator
It definitely does look like a PAL set. The fact that the entire face of the tube, including the black outer border, is visible, suggests a european design, and the pushbutton tuner with very few channels definitely suggests PAL. My guess is that the clipped co-ax you found went to the tuner/IF stages. It almost looks like someone was trying to jury-rig an outboard tuner into it to receive NTSC. Look for other component changes as wel, could be a hint into what the person was trying to do. Could have been trying to tap into the IF stage before the video amplifier. I've done this before on small black and white tube portables - by disconnecting the IF stages from the video amplifier tube and feeding a properly biased (and isolated... hot chassis!) composite video signal into the grid of the tube, it's possible to use a television to display composite video, to be used as a monitor on a computer. (Apple II, etc). Don't know how such modifications would help in converting a PAL set though, since the 50/60hz difference would probably hose everything, not to mention the different signal decoding and horizontal resolution.
Just a thought.
-Ian
Old 03-13-2005, 07:04 AM
polaraman's Avatar
<--1956 300B
It is a European set. All the writing is in French. The power supply has a clip that you can change to 4 different voltages. I may try later to see if I can get a raster.
polaraman
