Old 01-18-2011, 01:28 AM
Picked up a "new" TV!
This one's a Wilcox Gay ( no puns please )
I posted the details and pics over at A.R.F. since they can't see posts here unless they are members.
I had to save it even though it cost a bit too much and it's kind of rough, when will I ever get another chance at one.
I found out it's a Majestic chassis, or a Majestic uses a Wilcox Gay chassis, either way it's pretty cool looking for an early 50's 20" set.
The rebuilt CRT has a 1977 date on it, anyone know of Dunham Electronics in L.A.?
http://www.antiqueradios.com/forums/...c.php?t=155415
Well, just one pic here:
Old 01-18-2011, 10:20 AM
Thats a very fine looking TV. I prefer stuff more in the $20 range, but I'd of been very tempted to save that one too. Will takes lots of effort to get it looking better, but I'm sure you can pull it off.
Kevin
Old 01-18-2011, 10:51 AM
Hi Kevin, $20-$25 would be more in line with what it's worth in that condition but I just couldn't pass it up because it's an uncommon set.
The CRT being good and the fact that it was being maintained at least up till 1977 make the price a little more palatable.
Anyway it's all there and that's the most important factor, cleaning it up and refinishing it will make a world of difference.
Old 01-18-2011, 11:33 AM
kx250rider's Avatar
REAL TVs have TUBES!
That's rare! I had one, and I still have the Wilcox-Gay flop down door. I don't have the knobs or back, unfortunately. That's interesting about the Dunbar tube in there... I knew Ronnie and George Richardson; owners of Dunbar in the 70s & 80s. I bet my hat, that that 20" tube in there, came from a Kaye-Halbert or a Packard-Bell. My Wilcox-Gay set was the identical model, but had a 21" tube in it.
Charles
Old 01-18-2011, 11:38 AM
Kewl set ! Good for you for saving it, too !
Old 01-18-2011, 11:54 AM
Nice find! I didn't know Wilcox-Gay every made a TV. The only thing I knew them to make were disc cutters and reel-to-reel tape recorders.
Old 01-18-2011, 12:03 PM
Ralph S Ralph S is offline
It's interesting that you mention Dunbar. In the mid 60s I had them regun a conrac crt for me and change the phosphor to p16 for a kinescope recorder. Thay did a first rate job. I pass the building that they used to be in every day. It's one block west of La Brea on Venice Blvd (in Los Angeles) on the way to my office. I keep wishing that they were still in business! It would be really convenient for rebuilds!
Old 01-18-2011, 12:57 PM
GeorgeJetson's Avatar
GeorgeJetson GeorgeJetson is offline
Never seen that brand of television before,it does have nice styling though.
You must live in a mansion to be able to collect consoles!
No wonder this circuit failed,it says "made in Japan"!
Old 01-18-2011, 09:29 PM
John Marinello's Avatar
<-- "Byron"
Are you sure that date code is 1977, and not 1967? I'm astonished that someone would bother with a set that old in '77. Has anyone else seen such a thing as this before?
Old 01-18-2011, 10:44 PM
I'm sure on the date, it's printed very clearly, there are also a lot of replacement tubes including some RCA's with the late Logo and some Orange Drops under the chassis.
Old 01-19-2011, 12:51 PM
kx250rider's Avatar
Dunbar either hand-wrote or stamped the actual date the tube came out of the oven, so it's easy (unlike other mfrs with weird codes to figure out)
I have a 21AXP22 with a 1994 date from Dunbar... Gone to air though
Charles
Old 01-19-2011, 11:49 PM
Cleaned up the chassis today, removed a Mouse Skeleton!
I repaired the CRT base yesterday, found the G1 connection had broken off flush with the glass but I was able to scrape enough glass away to make a connection with a fine piece of wire and replace the base with a new one.
Tested in in my old Conrac chassis and it works great.
Old 01-19-2011, 11:56 PM
Wow! What a difference That has to be the nastiest chassis I've ever seen
What did you use to clean it ?
Old 01-20-2011, 01:20 AM
Wow! What a difference That has to the nastiest chassis I've ever seen
Me too, and I've had several sets that were Mouse infested including a Truetone that had three inches of Apricot pits inside and had a couple transformers eaten but was no where near this dirty.
The set was in use at least till the early 80's so maybe it was just really dirty to start with.
It was really disgusting but surprisingly in good shape under all that whatever it was.
I thought it was just Mouse pee but it may have been a combination of Nicotine, Mouse pee and dirt. The rust left after wire brushing by hand was very light and simply went away with some Rustoleum.
I posted a more detailed account of the cleaning on this page:
http://www.antiqueradios.com/forums/...55415&start=20
I'm waiting on some Micas for the Sylvania so maybe after I get that finished I can get this on the bench and see what's what, it has a half dozen newer Orange Drops in it already, probably from the 1977 repair.
Side note, the original CRT was a 20CP4D, Electromagnetically focused, the tub ein it now is Electrostatically focused and there was a jumper wire from the focus pin to the Cathode or possibly G2. I don't know what number this tube is, it's not marked, possibly a 20GP4?
Old 01-20-2011, 01:23 AM
John, I have seen it once before on this Hoffman:
http://www.vintagetvsets.com/hoffman10.htm
It had a date inside for a repair made in 1980 and the set still worked a little bit when I got it.
When I was working in a TV shop circa 1978-1981 we never had anything this old come in for repairs. We did fix a lot of Color sets from the 60's but that was about as old as it got.
