I always liked the 1953 era Philco TV's.
Here is one on Ebay - is it like yours? http://cgi.ebay.com/260701620235 Also, a few years ago there was found a pair of 1953 Philco TV's brand new in an old shop. I think they are in the WV radio museum now. When I saw a picture of those new Philco's, it really was what made me focus on TVs rather than just antique Radios. Carl
CW 1950 Zenith Porthole - "Lincoln" |
Here's mine: ![]() BTW, I got this set from a Thrift Store a few blocks from my House, they called me about it because I had left my number and told them I was interested in old TV sets. I tested the CRT at the store and knew it was weak but the set was so immaculate otherwise I bought it anyway. I've since found a rebuilt tube to put in it, from a relative of Charles no less. Last edited by Eric H; 12-08-2010 at 03:03 AM. |
I didn't replace the four section cap yet, I have to get a 500v cap to replace the 475v section.
I put a couple Diodes across the Seleniums to see how it would perform, I was getting about 285 volts of B+, probably a little high if the schematic is correct for this set, however the set fired up nice and bright, I had to adjust the Width and Horiz Osc to compensate for the new filter caps and the extra voltage. I will still have to change the four section cap, it's very difficult to get good Vertical Linearity and height together, also the Lin control is maxed out at one end, I suspect one section of that cap is in the vertical circuit. When I first got this set running, back around 2001, the Vertical tube went bad in a fairly spectacular display of arcing and meltdown in a matter of minutes, a new tube fixed it but I wonder now if the Cap caused it's demise, possibly reforming itself later with a new tube. I probably never went through this set and checked the resistors either, it was a quick recap to get it running and it worked well enough that I never bothered to do any more. Last edited by Eric H; 12-08-2010 at 03:04 AM. |
jr Pix 1 knobs on 53U1827 (purchased late fall '52) Pix 2 Fancy 21" '53 from Photofact cover Last edited by jr_tech; 12-08-2010 at 03:28 PM. Reason: add pix |
Wow. Thats as nice as they come.
Always like those era Philco's. Carl
I'm not 100% sure, it could be a 54.
I've found ad's on eBay for it and they were dated 1953, admittedly by the eBay sellers themselves. I did find a rubber stamped 3-27 on the chassis, if that's a date it would be the middle of 53 so it could be a 54 model. I'll look for some dates on the original tubes, if there are any, it's a high mileage set. |
