Old 12-02-2010, 12:53 PM
damen's Avatar
damen damen is offline
Originally Posted by ctc17 View Post
Good point on the solid state 3A3, but there is still allot of high voltage potential around the fly I wouldnt want to expose. If you hold your finger up against the tire it will cook it. I tried this with a hot dog.
The flys are scarce but available if you look around. They can also be subbed fairly easily.
They usually fail near the top where the 3A3 stick in.
I saw some of those solid state 3A3s, ill have to grab one and give it a try. See if it reduces the heat any.
I don't know for sure but I always thought it was the tube putting off Xrays that was the reason for the cage. When solid state sets came out that had no High Voltage tube they also had no cage. The 3a3 tubes also have a warning printed on them that says tube may produce Xrays if not shielded.
