Old 11-25-2010, 01:01 AM
ctc17 ctc17 is offline
Those are awesome sets and produce a great picture. I have been fighting at ctc35 with vertical issues. Turns out all those 'orange drops' go lossy and loose their defined value. After further investigation I found all the old red/orange drop caps in rcas are going lossy on all the sets I have.
Now that I got it working Im going to use it to make an IF/Chroma bandpass alignment video.
I wouldn't stress the 300ma cathode current fuse. Even if you pull the horizontal oscillator out the tube will red plate and never burn the fuse. You really need a chemical fuse for that purpose.
I have found the signal tubes like the IF one you found sometimes short if the set has been setting for a long period of time. A few good bangs on the table usually de-short the tube and it works fine.
Great videos and good to see someone else getting intimate with a late 60s CTC.
Old 11-25-2010, 07:28 AM
Chad Hauris's Avatar
Thanks for your observations and advice. I know there were a few RCA tube-type portables (maybe CTC-22 and 36) that used a circuit breaker system in the cathode of the horizontal output tube. The breaker had a thermal element connected in the H.O. cathode but it ended up opening the contacts to the power line, cutting off all power in case of a tube overload. Maybe it was somehow more sensitive to dangerous overcurrent than a fuse would be?
The later tube type portables mounted a thermal fuse near the horizontal output tube and I think it was in the cathode of the tube...it must have been able to detect overheating in the tube in case of no drive or flyback failure.
For some reason I don't think there were ever factory overcurrent devices in the horizontal output circuits of the console sets.
I had a flyback fire when I was a kid, in a CTC-31...luckily nothing else was damaged but I left the room with the set on and came back and it was filled with smoke and the set was playing with sound...I really wanted to get an overcurrent device on the flyback system which would try and help prevent this.
Also I remember reading in an old magazine about Sprague Orange Drops having a dual dielectric...paper and Mylar. I'm thinking in the present day they are just Mylar. I wonder if these old 60's era orange drops are more prone to the type of degradation in paper caps but maybe not quite so dramatically as the wax/paper type or the black beauties?
Chad Hauris
Old 11-25-2010, 08:40 AM
JCFitz JCFitz is offline
CTC.
After reading this I wonder if I should worry about the maroon drops found in Zeniths also as I'm getting ready to do the recap on my Zenith roundie.
