Old 11-23-2010, 10:18 AM
zenith2134's Avatar
Cool TVs that never got turned off.
Off the top of my head, I can think of at least 3 times when I've seen CRT sets which ran for years on end...solid state of course. Although the vintage Arcade game, Computer Space, used a General Electric tube hybrid b/w as a monitor, and arcade machines ran continuously as a rule...
But, it's always been pretty amazing how much use some tv's got and still kept going. We had a neighbor that took a used TV from me and ran it 24-7 for a few years before it got tossed. And as a kid, my grandparents had a small RCA color in their kitchen that was on for the better part of every day.
Kinda funny that manufacturers only usually guaranteed 2 years on the CRT.
Old 11-23-2010, 12:33 PM
ctc17 ctc17 is offline
We used to have some arcade games at the club I work at that ran 24/7. The screen burn was amazing and they crts had faded to a point where with maximum screen voltage you could barely see them in a dark room.
The key here is lack of thermal cycles. Parts and solder connections dont fail as much if the thing stays hot all the time. They seem to run till the crts are totally dead, 10 years or so.
Old 11-23-2010, 02:47 PM
leadlike's Avatar
leadlike leadlike is offline
At my office, we have several crts that have run for years. There are a pair of 8'' Phillips monitors that have been running for over five years 24/7. The worst part is that they are built into a fixture with no ventilation.
Also, we only just got rid of our two 36" crt sets that have been in our cafe for the last four years. They too ran 24/7. Earlier this year, one began developing all sorts of intermittents, so it was retired. The other's crt just faded to nothing over the last few months, until the picture became unwatchable.
My Dad's 2000 Zenith basically also runs 24/7, as he spends retirement falling asleep on the couch with the tv on all night.
Old 11-23-2010, 03:45 PM
When I was a kid, we had a 1981ish Sears (I think it was built by Sanyo but can't remember) anyways, that thing was NEVER turned off, it ran most of my childhood. My Dad liked to sleep with it on. When my grandmother on my Dad's side passed away we got her '80 Magnavox and ran the crap out of that. We kept the old one and it was given to me, in 1995 I finally got so sick of the damn thing with the blurry picture and horrible reception that I kicked the front of it in so my parents would have to get another tv. They bought me a 1995 Zenith for Christmas, It's one with the crappy CRT but it still works because I broke it wiring sound to it for the stereo that it was never meant to be hooked to. A cable wire flipped up onto the back of the CRT neck board and fried the CRT because, like an idiot, the set was on while I was doing "mods" to it. :P
Old 11-23-2010, 09:28 PM
JCFitz JCFitz is offline
My mom and stepfather own a 1987 Mitsubishi 60" projection that gets high usage.I fixed it up for them about 10 years ago when it came out of a beach condo where it only got used during the summer.The HV bleeder/distrubutor block had shorted. Ever since they have had it it gets turned on when they get up and never turned off until they go to bed.They even leave it on for the dogs.It's been run that way for 10 years and it will probably get run that way until one of the crts goes south and the color balance is unacceptable or they all 3 fade to a barely watchable picture.
The only other trouble they've had is the AFT coil in the IF kept drifting until it finally wouldn't stop searching.It has a built in capacitor and I suspect it went bad.Of course it's NLA.Could have probably got an external capacitor to tune if I could figure out the capacitor value but since they are on cable and have a box I figured why bother.I simply hooked it up to the video input and that was that.
Luckily this set was made before the infamous leaking electrolytic capacitors found in all late 80s to mid 90s Mitsubishis.I've run into a lot of those where you had to replace a whole lot of electrolytic capacitors and sometimes repair the circuit board traces and damaged components from the leaking electrolyte.Also of note was the terrible Mitsubishi projection made around 1990 where the vertical chip was run directly off one of the switching power supplies (rather than a winding on the flyback) in which a certain electolytic capacitor would go bad and the vertical Ic would receive twice or more it's rated voltage and it would burn up itself and a big black hole in the circuit board.
And it was one year later than the Mitsubishis that ate deflection yokes.
After the leaking capacitor tvs came the coolant fluid leaking Mitsubishis which also damaged the circuit board traces and components so I guess my mom and stepfather are lucky Mitsubishi had it right for that year.It still has a nice picture despite my stepfather's heavy smoking.I go over and clean it the screen,lenses and mirror a few times a year.
As you can tell I've worked on a lot of Mitsubishi tvs.they must have sold a crapload of them around here.
Old 11-23-2010, 09:51 PM
I just turned down a late '90's Mitsubishi big screen. And, their standard CRT sets of the '90's had the same cap trouble. In fact, I will no longer fool with any late '80's or newer Mitsubishi TV.
As far as TV's that never get turned off, I know an older couple who had an early '90's Sanyo 25" TV that probably saw 14-16 hours a day use. When they went out of town, which was fairly often, they left the set on 24/7. About 3 years ago, some caps in the vertical circuit gave trouble and I fixed the set for them. Then, their kids gave them a Dynex 37" LCD TV for Christmas. Fortunately, they took out the extended warranty because that one held up less than 2 years at 14-16 hours a day. It turned out that the needed repair part was NLA; so, best buy gave him a refund of the original purchase price. He took that money and bought a new 42" Insignia TV and still had money left over. I wonder how long that one will last?
Old 11-23-2010, 11:42 PM
freakaftr8's Avatar
Convergence freak!
My father in law has a 50" Toshiba projection tv from 2004 that never gets turned off... And when I say that I am serious about it. It really never gets turned off. He has 4 german shephards that live in the house and he uses it when he is not watching it for residual noise to keep them at bay. I had to replase a bunch of SMD lytic caps on the "hyper" board last year cause the horiz went nuts but other than that it looks like crap, the whites are pinkish red and there is a fox news logo burned into the lower left of the screen. There is also alot of screen burn in places. And its a little blurry and it's full of dust and dog hair. But it's still chugging along.
Another few sets werew those Funai "Magnavox" 19" TV/VCR/DVD combo sets that were made in the mid 2000's. Pieces of crap!!! The loaders would go south rendering the whole set useless as it went to shutdown after the click,click,click a million times. Those were placed in a special needs home that I used to work at. The guys there used them all day and night. There were 4 of these sets and one still works. The others rendered the ill fated doom of the vcr loader failure.
Old 11-23-2010, 11:48 PM
matt_s78mn's Avatar
matt_s78mn matt_s78mn is offline
Back in the early '90's my aunt and uncle had a late '70's Zenith Chromacolor II console that was on 24 hours a day and had been for years. One time when I was there and no one was watching it I turned it off... and boy did I get in trouble. Turns out the reason they left it on was because once it's off it wouldn't turn back on! They would have to fiddle with it quite a bit to coax it back into working again and I guess sometimes it was days before they could get it to work again. They certainly were cheap skates and didn't want to pay to have it repaired.
Old 11-24-2010, 12:01 AM
I think of the sets in some stores...they all get that washed-out look after a number of years, sorta yellow and fuzzy. We were in a fabric store last year and I passed the time looking at this little Panasonic bw security monitor they had hanging from the ceiling. It was all you could do to make anything out on that dim screen. 99.99% used up. One of the Targets had a line of 25" Emersons on a high shelf and they were starting to look pretty weak by the time they were retired. Another time we were at a Ruby Tuesdays and they had a couple Panasonic 25" sets near our table. One had a terrible pincushion problem (I guess) with the picture looking like an hourglass. I think the other one had vertical issues. I wondered how long they would get run like that before somebody pulled the plug.
Old 11-24-2010, 12:34 AM
compu_85's Avatar
compu_85 compu_85 is offline
Procrastination Expert
In 2003 I was attending Grand Valley State. They had computer kiosks all over the place, and computer labs with these terrible Sampo CRT monitors. No screen savers or energy savers were used, they ran 24/7/365. They all had the login window burnt into the screen, and the cheepie 14" displays on the kiosks did not hold up well at all. They were all dim and blurry, some were barley usable. Add to that the super yellowed plastic of the ones that were near windows... really made the place look run down.
I'll have to take a picture of my Lisa's original CRT... that machine got a lot of use. You can tell exactly where the rastor was, the phosphors are almost totally used up.
-J
Old 11-24-2010, 01:11 AM
wkand's Avatar
wkand wkand is offline
The old Kingdome in Seattle had a bunch of old Conrac B/W monitors in the aisles for viewing game highlights, etc. Many of them were in use from 1976 through the 'domes demise in 1999. Not 24 X 7 but heavy use nonetheless. The concession stands had Zenith color TV's, 1976 vintage, to view games while in line for a Kingbeer. They were in pretty sad shape (out of focus images, convergrence gone forever) when the dome closed, but they still worked. Likewise Sea-Tac airport had B/W monitors for flight info from 1973 through a major remodel in the main terminal in the early 2000's. Those WERE on 24 X 7. No idea how much service any of those sets received over their lifespans, but a pretty amazing service record.
Old 11-24-2010, 02:29 AM
eberts eberts is offline
I was on a service call in a nursing home, the main tv in the 'recreation" room needed a vertical height adjustment. The room was packed with residents. An old guy sitting next to the tv told me the set had been playing for 8 years 24 hours a day since he has been there.
I unplugged the TV, there was a gasp from every one in the room, then 12 elderly members slumped to the floor and died.
Old 11-24-2010, 10:18 AM
sampson159's Avatar
sampson159
sylvania d 16 console.played for over 12 years,24-7.great set that never failed.the crt still looked like new when it was finally put in storage.my brother pulled it out a couple years ago and gave it a try.no high voltage.the dreaded ho tube socket.he cleaned it with de-oxit and siliconed the tube into place.bammmm!set came on with just as good of a picture that it ever had.this was a set was purchased new from sun tv by my dad in 1972.another one of his excursions after working 2 shifts and no sleep.my dad would decide he wanted something new and he would go saturday morning after coming home from work.he walked in,told the sales rep,"this will be easy.show me the best set you have".when it was delivered,it was turned on and never turned off.never beed repaired,but i have cleaned the tuner more than a few times.
Old 11-24-2010, 04:14 PM
jstout66 jstout66 is offline
One set I remember being on ALL day was the CTC-31 tabletop 23" in my grandparents liquor store. They had a back-room with a recliner and couch, and grandma's sewing machine. That set got turned on Monday thru Saturday 7am-Midninght form 1967-1968 to 1981. It went thru 2 picture tubes and 2 flybacks. (my Uncle was a TV repairman) and when grandpa got a used 23" Chromacolor 2 to replace the CTC-31, that set stayed on the same time till the late 90's. The RCA even got sold used in my Uncles store when they got the Zenith as it was stilll working. I think grandpa got sick of putting in the 8 zillion 6GH8A's that sucker would go thru.
Old 11-27-2010, 12:45 AM
I work in the ultimate location for TVs that never get turned off: An airport!
Black-and-white CRTs last much longer than color ones in this job. There are a number of B&W monitors that were installed in 1979 that are still in use, though most of their CRTs are not nearly as sharp as when new. Of course, image burn-in is epidemic on CRTs that display fixed-position white characters on a black background.
Sony Trinitrons have been widely used in airports, and their biggest problem is/was loss of one color before the others. Early Sony sets needed regular gray-scale setup to keep proper colors (or for B&W display use); later models had auto-tracking circuits that worked well until the CRTs themselves went bad as described above. Some non-Sony sets actually have held their colors much better going on 10 years.
I know of one B&W monitor that was still in use as of less than a year ago, that is from probably the mid-1970's, and its CRT is in pretty nice shape (other than burns).
