like CTC17 said, engineered to make service easy. lots of little things, like plugs to disconnect the tuner/control panels, very easy chassis to set on the bench (can flip it upside down, the HV cage and part of the vert chassis makes a perfect stand) plugs that connect the filter cans (easy to take them out of circuit to check for leakage of the cap). IF section on a PCB but all the tubes are handwired so no PCB damage from tube heat. focus tube rather than Se rectifier, jumper provided for cathode current checks, all the tubes are easy to get at, just a lot of stuff like that. The only real weak point was the cheap adj pot board that failed. I guess from an enginneering stand point it makes since (the pots are not supposed to see any cycling), and I can't figure how it failed the way it did. the pot did not just have a bad spot, but rather the conductive part seemed to be just gone across 90% of the arc.
decided to check the cat current at reduced line voltages.
I put the set on a variac and dropped it to 105vac, cathode current on the HOT went to 180ma from 220ma with no change in HV (shunt prob just not working as hard) and no change in vert/horz size (compensation parts like VDR's and other bias componets prob accounting for that). bottom line is I think this set was engineered to work at lower line voltages, with higher voltages just generating more heat. I suppose this is a trade off on designs that did not include power supply voltage regulation. You can bet I will be using a variac to run this set. I kicked around an idea adding some resistance to the screen resistor on the HOT, set it up to operate at 120v and still get the lower HOT current. Not sure if I want to go adding circuitry. It would be nice if I could engineer in a jumper that would switch in a voltage drop, I will have to look over the chassis for this. I would prefer to make min changes in the orig design. A bucking transformer would be good but these old sets pull a lot of power, not sure how to size that. |
