Old 10-28-2010, 06:45 PM
Note that this set has an aftermarket "channel adjuster" control added onto the contrast control
That's a potentiometer with a switch wired up like this.
Looks like an AFC circuit in an FM radio. This can only work if the TV set does not use the intercarrier trick (4.5MHz sound IF taken off the video detector diode).
