Time to get this site upgraded, so we are passing the hat around. We appreciate any donations. Seriously, even a dollar helps. The payment page may be found here - https://www.audiokarma.org/support.html
Your function selector switch needs to be in the "TV" position for this measurement to work. If it is on FM or Phono, you'll measure open. Can you check that?
Confirmed. Open circuits on TV1 and TV2.
I checked T5A, the Horizontal Deflection Coil, it reads 12.7 ohms, specs call for 14 ohms.
