Another progress update
I've been slowly touching up the control area and working on the "picture frame".
The were many dings on the slats and around the control decals. ![]() I used Howard's Restore-a-Finish to clean and work out the blemishes. Then, I used a small brush and lacquer (clear or toned depending on the damage) to fill the dings in. ![]() Once dry, I sanded them flush being careful not to break through to the wood. It took several passed to fill the deeper ones. A more traditional (and quicker!) method would be to melt a tinted shellac stick into the dings, but it's something I've never tried. Then, I clear coated it with several coats of semi-gloss lacquer. ![]() Loads of dings in the frame too. I used some mahogany wood filler on the larger ones and shellac on the smaller. ![]() I spruced up the front panel with some red mahogany minwax stain. ![]() That leaves one major task - mask off the frame and paint the inside bead metallic gold.
