Old 10-17-2010, 12:20 PM
ggregg's Avatar
ggregg ggregg is offline
Couldn't pass it up
Prices have finally come down on these. Stopped at an old haunt Friday and their resident radio guy had just passed away. The family had starting marking down some of his stuff in the shop. Price was right so I snapped it up. The antenna is broken (of course), and the volume control is not original. I haven't even opened it up yet.
What can you guys tell me about 17" Predictas. Never owned or worked on one before.
Thanks,
Greg
Old 10-17-2010, 01:12 PM
marty59's Avatar
marty59 marty59 is offline
Do a search for some posts here first. Your set may be a series or a parallel filament set and there's been a lot discussed as well as some experience here!
You also need to assess it a little bit and let us know what 'cha got.
Old 10-17-2010, 05:18 PM
pretty sure its a powr tranny, I did one a while back, I will see if I can find the link.
I liked working on mine, the chassis comes out easy. becareful of the speaker leads, mine were frozen to the transformer, you do not want to yank on it or you will tear out the female bullet connectors on the audio out transformer.
I just cut the speaker lead and put on some new connectors.
I have been told the anoode lead just plugs into the HV socket. I did not know this and ended up disconnecting the anode at the CRT. That was a mistake since I could not put it back on with out removing the plastic head shell from the CRT, adding quite a bit of work to the process.
If your lucky the fly will be ok. I would not mess with it at all no matter how it looks. just get everything else checked out and see how it goes.
On mine only 1 of the 3 can caps needed work the other (a doubler and 4 section) were ok and are working fine. The bad one was a skinny can multisection that sits right up by the power transformer.
there are several paper caps on board. You need to decide it you want to pull the main board or not. I was able to replace all but 1 or 2 without doing that, the 1 or two were done from the top (crush or cut out old, J hook in new).
I had a couple bad tube sockets and one bad ground stake.
IMHO I would not pull the board unless I knew I had to, but of course this is just an opinion.
you may find a few out of spec resisotors, I had one on the brightness control and a sync tube (think it was a screen, not sure).
lastly the pots that control the vert lin/hight were a bit crunchy.
I spent a good deal of time with cleaner and cotton swaps sticks cleaning the board up so I could see what was going on.
The IF was fine, did not touch it.
Old 10-17-2010, 05:20 PM
http://www.videokarma.org/showthread.php?t=247056
this is the one I did
Old 10-17-2010, 06:39 PM
ggregg's Avatar
Thanks so much. This will be a great great help.
Greg
Old 10-17-2010, 08:27 PM
truetone36's Avatar
electronics packrat
Is that a Seeburg I see in the background?
Old 10-17-2010, 08:33 PM
ggregg's Avatar
Yes sir, an AY-100. I just rebuilt the amp and have the mechanism working well but it's not quite done yet. Original case is in very nice shape. 2 more Seeburg's in there too, a 100 C model that needs a LOT of work and an LS-2 that is completely done and for sale. Also an AMI C that I may part out or sell in addition to a Honda Goldwing and a Yamaha 650. I think I almost have enough winter projects.
Old 10-19-2010, 08:55 PM
Wizard256 Wizard256 is offline
AMI C!!
I did fix this jukebox (last June) and it was swelled up pot metal barrel jammed in the rotator/pickup mechanism, (piston) where it grips the record by carefully supporting this rotator and carefully beat on with wooden mallet to get this to extend out. This allowed me to free this gripper up with careful filing round the barrel. Then restored the mechanism by putting gears in correct relationship as it was attempted to be tinkered with because owner wanted to able to play the records at the events especially with that poor little motor still humming in jam.
Trouble 2 was tarnished contacts in the "logic" relay (behind the swing out panel for the coin mechanism) and one loose solder joint. This improved much that quits constant cycling of records in and out. hehe.
I hope boss or coworker had told the owner of this jukebox who have vintage stuff in the funhouse (hosts dances/big events) to do proper restoration on this one.
Cheers, Wizard
Old 10-19-2010, 09:12 PM
Smile
Thought these sets were only B&W. Is that the movie "Easy Rider" playing on that set? Oh wait, that's just your reflection...
Old 10-19-2010, 09:45 PM
RitchieMars's Avatar
RitchieMars RitchieMars is offline
VK Member
Awesome find! In my opinion, a Predicta of any variety is a great score. It's the type of set that commands a great deal of interest and collectibility even outside of the vintage tv hobby. It makes me wonder why someone hasn't, at the very least, imitated the Predicta style in the form of a modern television or computer product.
Old 10-19-2010, 10:19 PM
ggregg's Avatar
Actually there is one. I found a website on it but I forgot what it's called. Oh yeah, it's called a Predicta!
AMI C, My gripper is stuck in a 45 degree position too. I've only applied power to the lights at this point. Thanks for the comments. This AY-100 is pissing me off and every time I fix something, it seems something else goes wrong. I will prevail though. Ever bought something that was in absolutely great shape but had more problems than something that was all beat to hell? That's this one.
Easy Rider, nice one.
Old 10-20-2010, 04:25 AM
Very nice Perdition !
Old 10-20-2010, 10:56 AM
WISCOJIM WISCOJIM is offline
There was more than one producer of replica Predictas.
http://www.predicta.com/index.shtml
http://www.lectronradio.com/products...ovision_tv.htm
Unfortunately the Predicta computer was only a concept.
http://www.schultzeworks.com/philcopc/
Old 10-20-2010, 10:59 AM
You could also convert an old one if you wanted to.
http://www.onomy.com/blue/predicta.html
Old 11-03-2010, 07:25 PM
ggregg's Avatar
Waiting on caps for the DuMont, so I took her apart today and cleaned it up. It's a transformer set. Amazing how filthy a chassis can get when it has vent holes on the top. I figured what the heck, might as well see if she runs. Hooked up the VCR, got out the variac, and gave it a shot.
It works. Picture is only about 3 inches high so the horizontal needs some work but the picture is pretty darn bright and the audio was fine.
