I would sub out the color crystal first thing. It doesnt have to drift very far to cause exactly what your describing and seems to be the no1 issues I run into in the old rca sets.
Spraying the crystal wont tell you either. When they get flaky its to a few degrease of change, not freezing a warm crystal. You can pop any colorburst crystal in there for testing. One or the small ones out of a solid state set will work for testing. If thats the problem you want to locate an NTE358. There should also be instructions in the sams for fine tuning the osc frequency. Usually you inject color bars and ground out a few points. The color bars will float and barber pole, you will adjust the osc slug to slow them down as much as possible. This beat matches the osc in the set to the osc in your generator. You just need to be sure you have a fairly good generator that the chroma crystal hasnt drifted in. First sub out the crystal before tweaking any slugs though. Last edited by ctc17; 10-09-2010 at 08:29 PM. |
