I noticed that the top was made up of several strips of veneer. So, my first thought was to just replace the bad ones.
![]() I was concerned that the new strips would stand out too much so took it all off. I tried heat and steam, but no luck and reverted to brute force. I saved the large scraps to use as patches elsewhere. ![]() My next thought was to go old school and join the edges of my veneer strips with veneer tape and try to glue them down while maintaining a tight seam. Then I saw jeyurkon's Sylvania restoration project and the large sheet of veneer he used. I inquired and found out it came from veneersupplies.com. So I ordered up a nice 2' x 8' sheet of facecut veneer. More than enough for this set and my GE 810. First, I had to patch up all the dings from my forceful top removal. I also tightened up some loose joints. ![]() Here I've cut a new piece with a 2" overhang all round. ![]() I'm going to use the technique I picked up from Reece of coating both surfaces with diluted wood glue and allowing to dry. ![]() I used some clothespins to make sure it was centered over the cabinet before using an iron to re-activate the glue. ![]() Finally, I carefully trimmed it down to size with a utility knife and small block plane. ![]() That left patching a few damaged areas. Here's the worst one. I cut away the damage until I had a clean edge. Then rubbed over it with the side of a pencil to make a template. ![]() I used that to cut a patch from some of the old veneer I saved from the top and glued it in place. I brushed on a little clear shellac to seal the veneer. I'll be adding a few more layers and sanding down to fill the grain. I need to darken up that seam too. I think it turned out well so far ![]() ![]() Now, how to deal with that control area Then on to some toner lacquer.
Last edited by bandersen; 09-20-2010 at 01:02 AM. Reason: added some more pictures |
