Old 09-02-2010, 06:51 PM
YamahaFreak's Avatar
YamahaFreak YamahaFreak is offline
<-- CSXT 6038, EMD GP40-2
Yes. Regular shadow masks (either triad or in-line) are self supporting, but the aperture grill is made of vertical strips that are under tension. If overheated (by a intense bright white area), the shadow mask "domes" and can lose purity. The aperture grill, because it's under tension to hold the elements straight, doesn't distort until it is really overheated and starts to sag.
By the way, Trinitron grills typically have three very fine horizontal wires across the screen at about 1/4 height, middle, and 3/4 height, to keep the grille from vibrating. Once someone sees these, they may focus on them and find them annoying. If you haven't noticed them, don't try looking unless you want to notice them every time.
My 15" Trinitron computer monitor (trash find, rescued) has these support wires, but only two, about 1/3 and 2/3 up the screen. They don't bother me too much. (That monitor was made in '97, so it must be one of the last ones built with a real Trinitron gun, it's not an in-line gun.) I have yet to discover said support lines inside my 40" Trinitron, even looking very closely against a white screen.
Sony Trinitron Fan
Old 09-02-2010, 08:26 PM
Originally Posted by YamahaFreak View Post
My 15" Trinitron computer monitor (trash find, rescued) has these support wires, but only two, about 1/3 and 2/3 up the screen. They don't bother me too much. ...
Thanks for the sanity check - I may have misremembered the number of wires. It would make sense to avoid one visible right across the middle.
Not sure what the situation is with the 40"
Old 09-02-2010, 08:30 PM
site123a site123a is offline
So, were there a performance difference in picture quality between the newer short gunned Trinitrons and the pre-1997 ones?
Old 09-02-2010, 08:38 PM
Old 09-02-2010, 09:44 PM
Here's hoping I can dig up a replacement tube for this set from somewhere. It would make an excellent set for my parents' bedroom!
EDIT: I put up a want ad on Craigslist, we'll see how far this gets me. xD http://orlando.craigslist.org/wan/1935864489.html
Sony Trinitron Fan
Old 11-29-2010, 03:57 AM
Update
Against all odds, I have managed to track down a donor set to replace the dying tube in this KV-27S26. The donor is a KV-27S15, and shares the A68KZJ50X CRT. The donor was given to me by a friend of my parents after it suffered a fall from a dresser and sustained a large hole in the side of the cabinet. The set still works, with no damage to the picture tube. The tube in this set has much more life left in it than the one in the 27S26, though exactly how much more I am unsure of.
Now, I ask: Are there any things I should be aware of when swapping CRTs? (Other than the standard stuff like discharging the anodes and handling the tubes carefully) Both sets have been off for several weeks. With sets much larger than 19 inches, I struggle to find a good way of lifting the CRTs out of the sets. Ideas?
Sony Trinitron Fan
Old 11-29-2010, 02:29 PM
Do they use the same yokes and related convergence parts? If so, to avoid the hassle of doing convergence, I'd keep them attached to their CRTs and swap them as units.
Old 11-29-2010, 03:51 PM
That's what I was planning on doing, just swap and go. I have not examined the tubes side-by-side up close, but they share the same part number and look roughly the same.
Sony Trinitron Fan
